TwinTurbo.NET: Nissan 300ZX forum - Could try manually, via a power bypass, to see if the
jzack
on August 16, 2018 at 8:42 PM
No ideas? It seems like my lock works but it's very weak
posted by nissubaru
on August 15, 2018 at 03:22 PM
actuator works like it should. If it does, issue could harness wiring. If it doesn’t, probably the actuator is shot.
Driver door key lock not working, replaced actuator
nissubaru
22:17:44 08/13/18
nissubaru
15:22:31 08/15/18
Could try manually, via a power bypass, to see if the -
jzack
20:42:53 08/16/18
I believe the actuator is fine, the door locks perfectly but
nissubaru
10:21:42 08/21/18
